Discuss Preparation for Mosaics on floor in the The Welcome Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all,
After some advice. I’m tiling a 4m floor in 1 inch hexagon mosaics. The floor is green chipboard which is pretty secure but I would always use ditramat 25 on it prior to fixing but Schlüter have said not to fix anything under 50mm on to ditra 25. Anyone had the same issue? It’s not the sort of job I fancy doing twice!
Cheers for any help.
Dumbo
As above overboard with something like hardie backer but you may want to skim it over with a smoothing compound after to get it perfectly smooth to recieve mosaics
G
GoneGuy
Hardie Backer flies and screwed and then go over with a feather edge smoothing compound to fill any little gaps such as screw heads etc
One Day
Definitely wouldn't recommend orbry, wedi, marmox etc for small mosaics. Point loading would be too much and the board could compress.
Result would be a mess.
Thanks to you all. Seems to be that hardie backer board with a skim of levelling compound sounds favourite then.
Cheers for the help.
Reply to Preparation for Mosaics on floor in the The Welcome Forum area at TilersForums.com
voltage2688
