Plasplug polished porcelain sealer/impregnator
simonb43
Hi All,
I need the correct instructions for using the above sealer. Can't read them from the label and am a bit concerned that the application may be different to others that i have used. Sealing good old B & Q 400mm x 400mm porcelain tiles !!!!! Need info for 2moro please. Thanks
apply using a clean dry roller then remove excess with a dry clean cloth after 15/20mins,do this before and after grouting!:thumbsup:
hope this helps :thumbsup:
I hate to question your advice, but i'm sure it said to apply it and leave to dry. Have never done this before, have always done it the way you say. Just want to be 100% sure. Thanks for the advice.
after 15/20 mins it should be dry,thats when you wipe the excess of the tiles,sorry if it was a bit unclear:thumbsup:
Thanks loads mate. I assume i can grout after i have cleaned off the excess ? or should i wait til the next day. Sorry to ask basic questions but want to get this right as using materials that i wouldn,t normally use
i usually grout that day,i try and take my lunch or go for a smoke after wiping of excess just to make sure theres no problems
simonb43,
simonb43,
simonb43,
simonb43,
