new member
hi,
just joined and got a question straight away,i've got to tile a screeded floor which previously had wood on it,i need to remove the old glue and wondered who found it easier either chemical or mechanical,cheers,
john,
Welcome to tilersforums.com | Tile Forums | Tiling Forum!
Hello jonnieb1962, welcome aboard www.tilersforums.com. Stick around, I'm sure you'll like the place. 🙂
If that's too tough try some cellulose thinners. Used sparingly to dillute the glue.
This will evaporate completely from the surface. Keep windows open.
A heat gun may also help, but don't use this method with the thinners.
So basicly you have more than 50% coverage.
You can use a heat gun to soften the glue and scrape up, then an option is to slurry coat the floor to accept a thin SLC covering.
This will give a nice flat floor to tile too..:thumbsup:
cheers dave,i was thinking of hiring a floor grinder as its quite a big area or using something like nitromors but i'll give this a go first could work out a lot cheaper
Not a lover of nitromors.. but a floor grinder is the perfect option if you have the availability to use it.:thumbsup:
Hi Johnny, & welcome, as Dave says.If the glue is stiff it'll scrape,though it's probably like
the bitumen stuff used on vynils as you describe it. Just a note of warning,some of these adhesives from the 60s contain asbestos!! On a couple of jobs in the past we were told to not sweep it,only vacuum then have it latexed over as to remove it would have to be done by a specialist. I suppose the safety thing is no dust & quality masks,consider having it tested.The stability is key to your next move.
hi tecnik,
cheers for that i didn't give a thought about asbestos,i've always been led to believe you couldn't latex over vinyl glue,
hi there new to this im not a time served tiler but done a 6 month course couple of years ago with my brother done a few jobs since and they have been really good im very conifident at it and thinking of starting up myself can anyone give advice would be much appreciated
Hi Johnny ,& to be truthfull I can't say either way,😳 it was an instruction. Maybe to save money. Though it was the 2 part bottle & bag stuff & there were a number of tech guys had a look...Regards Nigel
new member
jonnieb1962,
Tecnik2000,
jonnieb1962,
Tecnik2000,
