Help for a novice DIYer
H
helen
hello All
I am redoing my kitchen and have taekn up my old kitchen tiles to level the floor and put doen new tiles. However under the old rubbish cracked tiles i have found some lovely original terrecotta ones that would be great to restore and keep!
The problem i have it that most of them are still covered in mortor and cement and its solid- i have been chilesling away for 20 mins and done about 1/3 tile!!
Is there an easier way of doing this or should i just recover them again??
Thanks in anticipation of all your hints and tricks!
helen:smilewinkgrin:
Hi and welcome.....Terracotta can be soft and hacking the old adhesive off may cause more damage than good if stuck that well, others may have a method for removal.
Hi & Welcome. Unfortunately, there is no easy way to remove it. As said, damage can be caused to them if using harsher methods like a chisel SDS. I think your best bet is to be patient. If you really want to keep them, take your time. You'll get there eventually!
helen,
Time's Ran Out,
helen,
Time's Ran Out,
