Grout or Sealant?
Stuart3br
Hi, I'm a "capable DIY-er" and have recently completed a major house extension (with help!). Now I'm tiling and fitting out an en-suite and main bathroom.
I have a question about how to finish tiles against a shower tray (resin+acrylic capped). Complication is I've used "Link Removed" which creates a seal around tray to Aquapanel backing boards. This seal has a 1cm lip that adheres to the top of the tray all round, and so the gap between bottom row of tiles and the tray is actually to this lip rather than the tray material itself. So would you use grout or silicon sealant in that final gap? Advice welcome.
Welcome to tilersforums.com | Tile Forums | Tiling Forum!
Welcome to tilersforums.com Stuart3br. Thanks for introducing yourself.
hi might pay to read instructions on the product in mention (not one i use ) but it recomends no Silicon /////////////////////// personally i would use a good quality Silicon to all internal corners hope this helps :8:
:welcome:...the link was removed as you are a newcomer...this is to help prevent spamming....
As mentioned above, expansion area's should be siliconed.
White silicon it is then! Yes I had read product instructions but they were a bit ambiguous I thought, so best I ask the experts. Appreciate the fast response, work proceeds tomorrow.
Happy New Year to all.
Grout or Sealant?
Stuart3br,
White Room,
Stuart3br,
White Room,
