Discuss Best adhesive for terracotta wall tiles? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Deester
Hi all,
I'm a keen DIYer and about to embark on my first major tiling job, I've done a few bits and pieces before but nothing on this scale. I'll be tiling our kitchen & utility room between the worktops and wall units with terracotta tiles (Mexican glazed "Talavera" tiles, 4"x4") and I'm looking for some advice on the best adhesive to use.
I'd prefer to use a tub of ready mixed stuff (one less thing to worry about) and the choice of products & brands is endless. Is BAL Grip Plus better suited for my project than BAL Green Star (Topps think so, obviously) and are they both better than Mapei Buildfix which is almost half the price?!
I've done a fair bit of reading on various forums and obviously, everyone has their opinion on the best brand, I just want to make sure I use the right product for the job without paying over the odds unnecessarily!
Thanks in advance,
Leo.
Q
Qwerty
No no to a ready mixed dispersion adhesive I am afraid. Got to be bagged cement adhesive. I like to use rapid set flexible S1 on terracotta
Deester
Bare plaster, the walls were skimmed and painted 8 years ago, I've stripped the paint off completely in preparation for tiling.
Rich Midge
Are the backs of the tiles flat and even not concave in anyway? Cement based is always going to give you a stronger bond but I'm struggling to think of a reason why you can't use a good quality dispersion (ready mix) adhesive. I'd give the back of each tile a scrape coat of adhesive before fixing. If you're planning on using a grey or coloured grout you might want to avoid ready mix as they tend to be white. Another thing to consider is drying times. In basic terms the longer you can leave a ready mix the better. Happy to proven wrong but I think you'd be ok to use ready mix if that's what you're comfortable using.
widler
Id usea standard set grey cement based addy .
You can mix as much or as little as you want with no rushing .
As you probably going to be using grey grout , would be better imo
Deester
Most of the tiles are flat, although they're handmade so a few are a little wonky, "rustic" would probably be the best description. Not a job I'm looking forward to, I guess I can blame the wife, she chose them and now I have to fit them! I was planning on using an off-white grout as the white of the tile is more of a cream colour (not as white as the photo makes out). Thanks for the advice, much appreciated!
Rich Midge
In all honesty, if you're happier using ready mix then you'll be fine. Most pros including myself tend to use powder that's not to say there's not a place for ready mix. A kitchen splashback, 4 inch tiles onto plaster is fine for ready mix. Granfix Multifix under the Ultra label is an excellent ready mix as is Bal White star.
Deester
Thanks, I'll be using powder for the grout (I've used ready mixed grout on previous jobs and it always seems to shrink and need extra work) but in terms of adhesive I haven't used powder before so I was a bit concerned about using an unfamiliar product when I've only got one chance to get it right!
Rich Midge
Ready mix grout is just awful, avoid, avoid. Lots of quality powder grouts but some bad ones too. Your best bet is to avoid the big sheds and find a local independent tile shop. Your more likely to get better advice professional products. If your only option is Topps you'll pay through the nose but should get quality products.
Q
Qwerty
Any manufacturer of terracotta tiles I have ever spoken to have always informed me that cement adhesive should be used due to the porosity of terracotta. I would personally never use tubbed gear let alone on terracotta, but I'm not the one tiling it :D
Dumbo
Hi all,
Thanks in advance,
Leo.
Slow setting cement based adhesive preferably one with an extended open time see if you can find a one which says c2te on the bag also prime the background with an acrylic or sbr primer . Do not use pva as a primer .
Reply to Best adhesive for terracotta wall tiles? in the Canada area at TilersForums.com
mcgtech
