Got a point . It's like they are going backwards with cement groutsPersonally I'm sick of cement based grouts and there issues, bring on the rise of epoxy I say.
Yes but if you go to Tesco you get 4 cellulose sponges for a pound, can’t for the life of me remember who told me 🙄Indeed I am H ...spent £70 on floats, washboy sponges, sponges and emulsifying pads last week..its all going on the bill 😉
The Tesco ones are good, don’t bung up and last a bitAndy hasn't bought cellulose sponges tho have you ! I saw those in Tesco at the weekend they look ok. I've used the cloth version in the past. The Kerakoll epoxy grout float sponges are £10 each
If I could I would give you best answer for that one hahaApparently Epoxy does set more solid if you use that hard on you have for me to clean the joints 😉
youll need plenty of sponges and scouring padsOh hahaha I was under the impression its less flexible once set.. Just impermeable, would be interested to know differently. Just on with a water factory at the moment and have 60sqm of epoxy on 200x200 dorsets to grout up this week 🙁
I noticed the white does start to turn yellowish after time ?
Thanks Paul.What about Keracoll ? 🙄Polymer modified cement based grouts are more flexible than epoxy. Or at least they are in Mapei's case.
Kerapoxy vs Ultracolour Plus as an example:
Flexural Strength (N/mm2): KP = 31, UCP = 9
Compressive Strength (N/mm2): KP = 55, UCP = 35
Ardion 90 is still the best IMO.Bring back Ardion 90 Grey and white grout😉😉
I try not to. They gave it to me large yesterday thought id throw the cat amongst the pigeons 😉😉Don't swear on here Simon !
Hi Paul. Posted this on the TT forum hope you dont mind ? No name mentioned just the facts 🙂Polymer modified cement based grouts are more flexible than epoxy. Or at least they are in Mapei's case.
You haven't proved anything Paul. If you're right I'll hold my hand up though.Fine, prove me wrong.
How much epoxy have you used and picked off tools days later? It's not as rigid as you suggest Paul. Yes simple logicNo i haven't proved it. Its just simple logic.
