Discuss Grout, grout and grout in the Tile Adhesive / Grout Advice area at TilersForums.com.
Simon Dale
1,108
Maidstone
As a professional tiler you would think I know. I dont !! Is Epoxy grout more flexible than a cement grout ??? I assumed that grout gives under stress. My assumption of epoxy is it adheres to the tile more than cement grout. If there is movement the tiles would tent rather than the epoxy failing. Thats why I choose not to use it. I do expect some stick so fire away:rolleyes::rolleyes: Your never to old to learn or Im an idiot:D
Simon Dale
1,108
Maidstone
Oh hahaha I was under the impression its less flexible once set.. Just impermeable, would be interested to know differently. Just on with a water factory at the moment and have 60sqm of epoxy on 200x200 dorsets to grout up this week :(
Was on tilerstalk and some young whipper snapper said epoxy is more flexible lol. I didn't know how to respond so asked the professionals on here ;);) As you say once cured its very hard
Spare Tool
The 200mm Dorsets are they dimpled/studded?
Lots of dots :(
Italy
I translated this found on the internet
EPOXY STUCCO - If Kerakoll and Mapei could recommend the stucco, they would certainly push you. It is a new market that are trying to create the two companies. Until a few years ago this type of putty was used only for certain particular situations (for example grouting of tiles / mosaics in saunas or in pools), but marketing will bring this product more and more in the residential area. Because it is interesting to push it to the producers: not all competitors are equipped to produce this type of putty and the selling price is much higher than the classic cementitious fillers. Because it may interest you: it is a much more performance putty, as it is MORE ELASTIC (useful for structural movements) and more resistant to abrasion. It is almost water repellent and resists very well to the chemical agents used in everyday life.
Stucco cementizio o epossidico? Tutti i pro e i contro | Rifaccio Casa - https://rifaccio.casa/2017/pro-e-contro-stucco-cementizio-o-epossidico/
Reply to Grout, grout and grout in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Question
