Which wet cutter to buy?
Anybody used rubi nd180 smart ?
Just bought the wet cutter from tile giant but i hate it!
It was only about £80 as it was a show cutter.
Water gets absolutely everywhere unlike any other cutters I’ve used previously and also doesn’t leave such a good edge.
Any recommendations?
I’ve got a Rubi nd200 and also got a variable speed grinder. I’m using my grinder more than my wet saw
I tend to use my wet cutter inside in winter couldn’t be bothered standing outside holding electricity in the pouring rain
How do you find the that grinder? Works well for cutting and polishing edges?
With the right blade I was cutting 12mm thick marble, and also using a bullnose attachment as well as polishing pads to clean the edges up
Brilliant. I have a cordless grinder. I’m thinking about getting a variable one to use for polishing. Do variable speed grinders offer any advantage when cutting? Do diffent tiles cut better at different speeds? What are the speed settings on that bosch? :grinning:
I had an nd 200 and then got nd 180 the proper one not bl or anything like that because I had a bridge saw for larger tiles
Have you ever tried the little Bricollina? Best small wet saw for around the same money as the nd180 and the cleanest of them all imo
Off top my head I think it’s around 3,00-1100. Comes in handy when polishing and cleaning cuts. I was using different blades at different speeds to get good cuts on the marble.
Brilliant. I have a cordless grinder. I’m thinking about getting a variable one to use for polishing. Do variable speed grinders offer any advantage when cutting? YES Do diffent tiles cut better at different speeds?YES What are the speed settings on that bosch? :grinning:
a lower speed, avoids overheating of the blade.
you will have a slower but continuous cut.
in any case, each tile is different from the other,
using it, you can understand better
I do have a variable grinder/polisher but for cutting I use a standard cordless grinder for virtually all cuts I do.
I just use a Bosch 18v Grinder.
I used a combination of blades- Montolit CGX and various Chinese blades. I don’t alter the speed depending on what I’m cutting. I use a grinder.
Some of the cheaper blades I now use mean that the Montolit have priced themselves out of the market for me. On cutting blades anyway. I’d buy another STL blade as I find it really good.
Fitwidge,
Blunt Tool,
Fitwidge,
Blunt Tool,
