Discuss Tile trim with metro tiles in the DIY Tiling Forum area at TilersForums.com.
88
Leicester
I’m planning to use an L shaped trim for metro tiles with bevelled edge. Is it best to always have a cut edge agains the trim or doesn’t it matter? Just wondering because of the gap on the bevelled edge or will it not be noticeable as the adhesive will level it out a bit?
1,003
Hope Valley, Derbyshire
Hi Rachel.
Without knowing all the details. Do not put the cut edges into a grout joint, especially when they are the Metro tiles.
You may find you will need a different size trim dependant on where on the tile the trim will sit.
For example - manufactures edge may be 5-6mm but when placing trim on a cut edge it will measure 6-8mm.
Hope this helps.
John Benton
1,138
Leeds
Still waiting for a pic off someone who has mitred metros......:)
Just for you Andy ;)
Reply to Tile trim with metro tiles in the DIY Tiling Forum area at TilersForums.com
