Italy
I'm sorry, but I can not expose my equipment.....
my wife would not let me expose it at home ....😉
If I needed it...... Then I would buy it.
Excellent mate....How do find using a grinder Andy? 😀
Excellent mate....
blades for the grinder that cut faster so as not to spend so much time using it.
Laser level is probably one of best pieces of kit I have ever purchased . The amount of time it saves when setting out bathroom walls is loads . Also when pricing up floor work it is very easy to see how much the floor drops so you can calculate how much levelling comp you need . Also on some floors very easy to put in set screws prior to levelling to get a very flat floor . The more you have one the more uses you will find to improve your working practises.I don't use a laser either Andy. Take sigma cutters for example, I was due a new cutter as my rubi 600 was basically worn out, now I couldn't ever use a rubi again.
Saving time means you don't have to rush .Can see how may help on a floor.
But it's nothing my 3m straight edge can't do.
As for saving time...... I gave up rushing year ago... 🙂
you used them as shims?
Lol I got a sigma 300 mm cutter new £100 about 26 ish years ago ? It replaced a nicobond one !!!! Last December I bought a rubi tx 1200n and stand over £800 trade on black fri deal !! Shows how tiles have changed aswell I got 7 different cutters plus cordless and 110 tools and edges up to 5m long I used to drive a Morris 1000 traveller back then now it's a VW t5 and that's too small ! LolThe only thing I can add to that apart from the said string line is a TS40. The best new bit of kit I ever got was my first Sigma.
have to agree.. I have a laser kit I bought 2 years ago ... It's Still in the box .. Never have used it..If I needed it...... Then I would buy it.
I've managed 36 years without a laser so I don't need it......... Would it make my life easier?.......... Maybe, but to spend £200 to find out imo.... Is a waste of money.
That's just my opinion... 🙂
because it is the wrong laser. 🙂have to agree.. I have a laser kit I bought 2 years ago ... It's Still in the box .. Never have used it..
