A
Alex111
Can I use hardwall as a backing to tile onto. I've been told by many u can and u can't. Many thanks
Thistle dri coat would be advised
British gypsum say no as it is one part of a two part system
I remember my chat with bg there was one under coat they would recommend but not hardwall . When I was trying to get an answer why it wasn't suitable and not just take because I said so I got accused of being aggressive.BG change the goal posts to suit by the sound of it.
Which undercoat do they recommend?I remember my chat with bg there was one under coat they would recommend but not hardwall . When I was trying to get an answer why it wasn't suitable and not just take because I said so I got accused of being aggressive.
That I can't remember you will have to call bgWhich undercoat do they recommend?
Bad bad idea...What's everyone's views on bedding shower trays on to ply wood with sand and cement.
If you make a screed mix that is meant for 75mm plus so thin bedding under shower tray there should not really enough thickness for it to be strong enough . Have removed a few trays which were s+c bedded came away really easy. We always bed flexible tile adhesive , much better product to use at those thicknesses .Bad bad idea...
Funny thing going slightly of topic . I know a plumber who had a cracked tray . Bedded without sufficient coverage so told by manufacturer his fault . This tray is also designed to sit on legs so far fewer points of contact compared to bedding on muck so how does that equate .The sand and cement isnt meant to glue the tray down its just to bed it down, if you come in the next day and start yanking corners up it will move.
Think about the Mira flight leg kit...are the legs glued down?
