Discuss Washboy Woes in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Italy
u
J Sid
two problems here, sponge to wet and trying to remove to much liquid from the floor in one hit.
try shorter sweeps across the floor then work up to longer one to you find the max.
I have ordered the ramondi sweepex. Doing a 30m polished porc floor next week so will give it a go there and report back.
Let's hope so! With it being polished porc, it's recommended to use flexmaster additive with the 3000 to help adhesion to the polished edge of the tile so might take a little more washing off.
H
hmtiling
Unless your using an s2 adhesive I'm not sure that you'd need an additive in the grout
Tilemaster have recommended that you put the additive in when using highly polished porc to help the grout bond to the polished edge. It happend with another tiler who uses the same shop as me, the grout came away from the edge or edges of the tile and that's what they said.
Italy
@Simons70
This right trend.
because it uses the sponges disposable?
that measures are they?
There are no longer in the catalog raimondi
not cost more?
Simons70
@Simons70
This right trend.
not cost more?
Cost less,clean better even when is new,not like the old one who need to be used for a while until start to clean,and most important,easy to use for old man!
Raimondi Sweepex Sponge One Piece Float 12x26xh3 RA395UG
Italian made Top of the Range High absorption Sweeepex Sponge Float containing nylon that gives long life quality and exceptional cleaning performance.
Sponges are Glued to Trowel Handle.
Price: £4.10
Kwik Split Raimondi Grout Floats & Sponges
Italy
Price: £4.10
arrrrrrrrrrhhhhhhhhhh.
I use 13x30 sweepex . sponge is same to your.
start to clean first pass.
only difference. My cost less:p
Frattazzi spugna 13x30 cm - Raimondi s.p.a. professional tile tools
Reply to Washboy Woes in the Tile Tools | any Country any make any model area at TilersForums.com
Apatel
