Newish (2years) Tiler - How Do You Guys Do It??
Hi Guys & Girls
Iv been tiling for just over two years now. Needed a career change after years of unfulfilling jobs so decided to bit the bullet and go self employed. Started by doing a 6 week course then following a tiller round (chief tea maker) and started with small jobs. Im over two years in now and have not looked back. Still being new I stick to bathrooms (not wet rooms) and floors.
Anyway I have got to the stage where I am not able to ask other Tilers how they do things so opinions from you fine people please.
1: Window reveal - How do you guys keep the cuts clean around the window reveal. I use a rubi cuter but this leaves rough edges on tiles. Wet cutter (best finish IMO) is not an option for most jobs. I use sand paper to smooth off the edges and an electric sander some times but I am never completely happy. Is there another way. The long tiles on top of the window look the worst. I like to butt the trim right up to the tiles. I am after a finish to match the look of a non cut edge of a tile (within reason).
2: Battens - For example if I am starting with a full tile from the bath and run the tiles around the wall I batten it off. Question is how do you guys then work down. I am currently removing the batten when dry and laying the next row and battening it off again. This time consuming and a pain with solid walls. I end up holing the batten in place with Silicon and wooden wedges. Is there an easier way?
I normally work in properties with terrible walls so If i need to pack it out trying to hold the batten in place becomes harder.
Cheers for the gems of wisdom in advance 😀
The window reveal ,the cut edge ,put away drom the trim ,then Silicon back edge
The battens what i do if you go full tile off the bath is ,put the tile in with spaces dry then batten up to it ,you understand
I see what you are saying. I do this too but was looking for other ideas of battening to the wall rather than the standard timber batten screwed in.
Thanks for the reply.
Not sure what you mean around the window, cut with rubi or wet cutter are fine upto the trim or window?
Hey
For example today I was cutting a 60cm ceramic tile around the top of the window with my dry rubi cutter. Once snapped it leaves a jagged edge which is not even. Once trim is butted up to it and a different colour grout to the tile goes in its noticeable. I sand with sand paper and an electric sander some times. I am looking for other options really. My wet cutter weighs a ton so its not practical to use one most jobs.
I tiled outside a house once ,someone already put the batten on the wall ,a piece of 4 x 2 quite funny
I think you might need a new wheel on the Rubi, either that or the tiles are cheap ceramics which chip on the edge no Matter what you do.
Well someone's got to say it...trade rubi in for a sigma 😉
Can't remember last time i saw a bath level enough to start with a full tile on it, and even if level they've all got a slight curve on em, i always start with the lowest row of tiles from floor off batton and work round and up to the bath, batton out above bath then cut into bath once walls above gone off, but hey apparently I'm behind the times for even using battons, stafs and datum lines 😉
McLovin,
dbstiling,
McLovin,
dbstiling,
