Porcelain Tiles Cracking
jonnyc
did a porcelain floor just before Xmas .client calls me this week to say that tiles cut around external corners have cracked .been round and they have too even with ditra underneath . Anyone know why this happens . It is certainly not the first time . I really don't think I should be responsible for putting this right , these particular tiles were on sale at b&q but others in past have come from reputable tile suppliers
The internal cut in the tile is to Sharpe, it becomes a stress point.
Ideally this should be a curved radius so any load or stress in or on the tile has no easy place to start if it wants to fail. The ditra has no effect on this I believe.
Hope that makes sense Jonny
Hey Jonny,
Hope you're good mate.
Is it just tiles with an 'L' cut?
I had this few months ago, there was too much tension in the tile,
They broke, one after another, got a new batch, they were fine.
I was informed they'd been overfired causing too much surface tension.
Who's too quick now @JulianSidney! Haha
I get that it's a stress point but do you think it is the quality of the tile that causes this.it could be very costly if it happens few years down the lines and can't get replacements and I was blamed for the cracking . I wonder how I would stand if a client tried to sue me .?it has nothing to do with the tiling in my view
julian exactly.
pierce point intersection with milling cutter 10.8 mm 🙂
I expect the quality of tile does not help, but as @antonio says, mill corner out to a radius or drill corner first with, say a 10 mm bit and cut to corner. This would be the 'material engineers' advice if you were to ask one.
This should done on internal cut on tiles, but who does it? I will use the grinder to put a radius in corner, lazy, yes! But have only had one go in may may years .
tiling, engineering, corner of windows and doors etc
Its all physics. Energy from pressure or impact will have reduced affect if it travels around a curve rather than sharp 90 degree turn.
Thanks for the advice . All makes sense .i need to get up to speed on porcelain. So used to fixing stone for last 30 years and don't seem to have same problem .were now doing loads or porcelain and I guess that even though we know how to fix a dead flat rectified floor there are other considerations.
Everythings porcelain now,its getting ,harder ,as well ,have to learn about stress points ,guys on here will help ,
How did you get on with this job jonnyc? I just looked at a job yesterday that I done a month ago and the very same thing has happened with a 60x60 glazed porcelain, I have layed loads if this type of tile in the same way Over the years and this is a first for me, tiles were hard to split on the sigma does anyone know could this be related to the cracking?
think its just one of those things that are meant to haunt us. just luck whether they crack or not .what pisses me off is that client thinks it is fixer fault not the tile
So if the brakes fail on your car and you hit another car it's your fault. Who do they blame when the washing machine breaks down? The guy who delivered it?
I try to make myself understood.
I state that for now I have never happened, breaking problems.
with grinder never reach the end point of 90 °.
stopping more than 1cm from the point.
break tiles with your hand. then round off with a grinder. inside corner.
I hope you understand. try not cost anything.
I understand @antonio, thats how I do it 🙂
jonnyc,
Italy,
jonnyc,
Italy,
