Depth Of Slc Over Heat Mat System
It will state in the pdf of your choice of slc , the minimum depth required , some say deeper over timber floors ..
But If your heat mat says 8mm , then isnt that your answer... 🙂
But why do most people only just cover the UFH then and not go thicker? Thats why I asked.
I'd normally go 2-3mm over cables Sharon, coupled up with a solid bed of adhesive using a 10mm trowel wiggled down to a 5mm solid bed you've got 8mm coverage there.
Always put down between 6-8 mm.
Webber floor flex states 10mm min over timber.
For mosaic i always do two layers as the second only a couple of mm and rolled out with the pin roller
I'm using Weber Floor Flex. How long do you wait before you put down second layer?
My next question is how the hell am I going to lift a tub full of 25kg of slc and about 4-5 litres of water ? Lol
I always let it dry over night and prime between coats.
Put a board over the wire and knock up on that in the room. Dont forget clean water and a sponge for any splashing
It's so annoying there's a nice flat floor lovely for mosaics but the customer is having UFH. Poo 🙁.
Tiling on Underfloor Heating
MTiler,
Dave,
MTiler,
Dave,
