Discuss Depth Of Slc Over Heat Mat System in the Tiling on Underfloor Heating area at TilersForums.com.
MTiler
Always put down between 6-8 mm.
Webber floor flex states 10mm min over timber.
For mosaic i always do two layers as the second only a couple of mm and rolled out with the pin roller
I'm using Weber Floor Flex. How long do you wait before you put down second layer?
MTiler
My next question is how the hell am I going to lift a tub full of 25kg of slc and about 4-5 litres of water ? Lol
jobdone
533
Chobham
I always let it dry over night and prime between coats.
Put a board over the wire and knock up on that in the room. Dont forget clean water and a sponge for any splashing
MTiler
It's so annoying there's a nice flat floor lovely for mosaics but the customer is having UFH. Poo :(.
Reply to Depth Of Slc Over Heat Mat System in the Tiling on Underfloor Heating area at TilersForums.com
  • Poll
Hi Guys have a big gap above tray to fill 2cm high 1cm deep (3/4in x 1/2in) Any suggestions...
