Discuss Depth Of Slc Over Heat Mat System in the Tiling on Underfloor Heating area at TilersForums.com.
MTiler
It will state in the pdf of your choice of slc , the minimum depth required , some say deeper over timber floors ..
But If your heat mat says 8mm , then isnt that your answer... :)
But why do most people only just cover the UFH then and not go thicker? Thats why I asked.
Dougs Third Go
I'd normally go 2-3mm over cables Sharon, coupled up with a solid bed of adhesive using a 10mm trowel wiggled down to a 5mm solid bed you've got 8mm coverage there.
jobdone
533
Chobham
Always put down between 6-8 mm.
Webber floor flex states 10mm min over timber.
For mosaic i always do two layers as the second only a couple of mm and rolled out with the pin roller
Reply to Depth Of Slc Over Heat Mat System in the Tiling on Underfloor Heating area at TilersForums.com
  • Poll
Hi Guys have a big gap above tray to fill 2cm high 1cm deep (3/4in x 1/2in) Any suggestions...
