Discuss Help! Tiled wetroom floor looks perfect but grout doesn't dry out! in the Australia Tiling Forum area at TilersForums.com.
P
Paula
Are you 100% sure water isn't getting under the screen ?
Well, all I know is that the tiler scraped out all the grout on the wet side of the screen and replaced it with epoxy, which still looks intact, then we put a large amount of clear silicone where the metal frame of the screen meets the tiles. So I would say it was almost impossible for water to get under the screen from on top of the tiles. Strangely, the grout does not get wet on the 'dry' side until a couple of inches away from the screen!
Dave
Subscribed
1,000,000
Co.Durham
It seems it could be creeping in the adhesive bed... How is the drain sealed at the tile edges ?
P
Paula
The tiler didn't leave much room between the tile and the metal drain edge, but the tiny gaps were originally sealed with ordinary Bal grout, and now Mapei epoxy (although I can't guarantee that he was able to scrape out every tiny bit of original grout....
P
Paula
I've just tried to take some photos of the wet patches of grout on the 'dry' side of the screen (12 hours after last shower!). Used a low quality image as I had trouble uploading photos before, but I can try higher resolution if you can't see anything!
Dan
Admin
1,318
Staffordshire, UK
It possibly just needs regrouting and some care going into making sure it's mixed and she's off properly with not too much water.
The D
That's very interesting, deanotile! So where exactly was the water coming from in the shower? Do you mean from somewhere in the tray? And, more importantly, how did you fix it?
one was a leak from the shower control where the plumber had not compressed the olive enough and the water was soaking throgh the adhesive and coming out in the grout joints on the floor and the other was a badly sealed wall jet and the effect was much the same as the first one. the plumer fixed the leak and the problem was solved
Reply to Help! Tiled wetroom floor looks perfect but grout doesn't dry out! in the Australia Tiling Forum area at TilersForums.com
  • Poll
