Discuss Help! Tiled wetroom floor looks perfect but grout doesn't dry out! in the Australia Tiling Forum area at TilersForums.com.
P
Paula
Hi everyone
Thanks again for all your wonderful replies. You convinced me that what we had wasn't normal and that I should push for a solution.
I asked the builder to come and have a look at the shower after two months (!) of not using it. He brought a moisture meter and discovered that the dark patches (there were still some) were, in fact, still wet. I also pointed out the very slight cracks in some of the grout. He agreed to consult with BAL again, and then decided to scrape out all the grout in the shower tray area and flood the joints with a liquid adhesive, so that it would flow into any gaps under the tiles.
After another 2 or 3 weeks he then got his tiler to grout with Mapei epoxy (medium grey). I must say this looks fabulous: not really any different in colour or appearance to the Bal cement grout when dry, and of course stays exactly the same colour when wet. I really wish we'd had this in the first place!
We have now been using the shower for a couple of weeks without any problems: no cracking, and still looks perfect. Only time will tell whether it can stand up to the rigours of movement on a suspended timber floor (although there is not a lot of movement currently), but hopefully given that it is fine so far, this bodes well...
Of course I will keep you posted if there is any change, but hopefully this thread will be of some use to others experiencing similar problems in the future. In my opinion it really makes sense to use a fully waterproof grout like epoxy in a tiled shower tray, but of course only after making sure that the tiles have been bedded down properly in the first place.
Thanks again,
Paula
P
Paula
Just thought I'd update you with what has happened with our wetroom over the previous weeks. The epoxy grout in the wet area has stood up very well, with no obvious cracking, and always stays the same colour, whether wet or dry. We're very pleased with that. HOWEVER.....despite re-applying silicone along the base of the glass shower screen separating the wet area from the rest of the bathroom floor (which still has cement grout) so that no water could creep under, we seem to have water seepage along the grout lines on the "dry" side of the screen, so that there are now unsightly wet patches and efflorescence (presumably where water underneath is evaporating from the surface of the grout) extending to about a metre and a half beyond the shower screen. We have recently been away for a couple of weeks and when we came back the dark patches were still there, but got worse when we started to use the shower again.
I mentioned that this was happening again to the builder and he says that water can't possibly be getting in through the shower tray with the epoxy joints, so didn't see what he could do.
As before, we think that the permanently dark grout patches and efflorescence look messy, and are worried about water collecting under the tiles.
Has anyone any thoughts on what could be happening??
Thanks,
Paula
Dan
Admin
1,318
Staffordshire, UK
Could it be from getting out of the shower wet to dry yourself? Or condensation perhaps.
I guess it doesn't matter too much what's causing it, the solution is going to be the same again I think. Regrout with epoxy?
P
Paula
Thanks, Dan, for your reply. No, where the worst patches are are well away from where we dry (in fact, they run from the glass screen to under the wall-hung basin, where nobody ever treads). And it's a big bathroom so we don't get condensation. The odd thing is that at the drying end, whereas the wet grout always used to dry out pre-epoxy, now where it gets wet it doesn't seem to dry as well, so looks permanently wet (even after 2 weeks of holiday!). The problem is definitely worse since we put epoxy in the tray: it's as if the water is escaping from the tray to an area where it can evaporate.
Surely if we epoxy the whole floor, it will just sit under the tiles? Do you think this is ok, or should we be worried about water escaping from the shower area under the tiles in the rest of the room? We really can't see how it can travel under the shower screen, but that's what it looks like!
Stab in the dark here, trouble is the two week drying period u've just had might scupper this theory a little :D
I recently witnessed a wet room floor that indeed kinda looked like it was leaking from beneath the screen.
In actual fact what it was, was capillary action on the screen itself.
It was sucking water uphill from the drain and trickling around the contours of the screen, making the dry bath area wet.
Just a theory mind :D
It could be completely bonkers too haha
The D
I have not read all the replies so sorry if im repeating whats been said. I have had two wet rooms with the same issue and both times it was a leak from the shower .The only way for the water to go as the walls and floor had been fully tanked was through the grout, so it was seeping through the grout from underneath the tile, not water getting in from on top.
P
Paula
That's very interesting, deanotile! So where exactly was the water coming from in the shower? Do you mean from somewhere in the tray? And, more importantly, how did you fix it?
P
Paula
That's very interesting that you've had the same problem! But do you think I could be getting the same effect (ie capillary action drawing water from the drain to the shower screen) even though the grout lines from the drain are filled with epoxy (which is supposed to be impermeable to water)? Sorry if I'm being a bit dim here, but do you mean that there is water under the tiles around the drain, or just water lying on top around here?
So what, if any, was the solution in the end? I'd be very interested to hear!
Reply to Help! Tiled wetroom floor looks perfect but grout doesn't dry out! in the Australia Tiling Forum area at TilersForums.com
  • Sticky
