I am thinking it would give a nice neat edge to Silicon around the edge of my bathroom floor.
Is this advisable, or should I stay with grout?
This should assist you no end......
http://www.tilersforums.com/tiling-forum/72833-newly-tiled-hallway-but-gaps-all.html
What's the bathroom floor going against, tiles or skirting?
Tiles.
aaah! So do you mean all internal corners on that particular job, or all internal corners?
Pretty sure on some bags of grout it says along the lines of 'internal corners to be filled with Silicon'..
I've definitely seen it, but can't say which brand it was...
Or you could double pack with grout and Silicon... Best of both world then.... Or is it the worst lol
Anyone who can make an expansion joint look anything better than average is a better man than me, apart from the fact they are not meant to be grouted!! Interestingly, I was grouting with micro max smoke a few weeks ago and was aware we had no matching Silicon so I grouted all the corner joints, I was not overly proud of the result but the customer was happy. Maybe we look to closely in to our work who knows but I will be sticking to Silicon for movement joints and grout for grout joints.
Tile to tile, you want to Silicon, so it's water tight (or as water tight as it can be anyway...) 😉
You've changed your tune lol
Here you go Charlie, there must be a colour here for you
http://www.countyconchem.co.uk/grap.../ottoseal-s100-sealant-colour-chart-large.jpg
Personally i Silicon all internal corners.... If anything it means i don't have to be so precise with my cuts![]()
Thats an impressive range! I knew they did a good neutral curing Silicon for stone use, but didn't realise they had such a colour range!?!
