Spiked roller or not ?
I could never see how these trowels worked as they put no key onto the floor, yes you got the floors flat, but there are no teeth to bite the adhesive into the floor, quality leveling compounds seem to key themselves in.
you should always use the flat side of the trowel to "butter!" the floor, then the tile..........then (with the notched side.. apply adhesive to the floor!) .......thats how they are supposed to work...
(but there are much better methods today!).....
Lee
I think I posted in another thread about the spiked rollers, I wasn't impressed. But if you try my method ie. forming bays and flooding. I use Levelflex or Mapei renovation screed, a word of warning, make sure you fill all old services.
Don't make the mistake I made the other day, I thought I had filled all the holes in this 1st floor bathroom with foam and compo, as I came to my last pour I heard a shout from the ground floor "hey Phil are you leveling two floors at once?" I had missed one hole partially hidden under the plasterboard, my slc was flowing to the living room below.As luck had it this is a raw building site, so no damage done, glad it wasn't a new cream carpet below,:yikes:
it does happen Phil.......like hitting pipes TBH!
all the best
Lee
Phill, I can't reply with quote but your story is funny!! No2 on the list of don't do's when slc-ing, only betted by leaving your van keys in other end of room and unable to reach them!! I've done both in past and will do again in future!
Lee
That would make perfect sense Pro!
My old man swore by these trowels and his floors never came up, i can't remember using any myself as most of the time in my teens/early twenties i was hungover at work and round notched trowels had been Introduced by then!!
I must admit......the old way is still the best IMO.....
and I think you are calling me OLD........in a roundabout way..........hehheehheheheheheehe
In answer to your question, give the roller a go, it might make a difference to your SLC finish. I bought one a few months ago and I think it has made my finish better. Obviously it gets rid of air bubbles, but I think it also contributes to the flow of the SLC as well
Been there done that Phil.
Poured a bathroom floor & missed a gap & watched the slc disappear heading for the kitchen ceiling.
Luckily there was some glass wool lying & used that to plug the gap.
Quite right,
Spiked rollers not only get rid of air bubbles (which can show through soft flooring finishes, not so important for tiling) but most usefully break the surface tension of the SLC allowing it to flow out like it's mixed much thinner. It doesn't make much difference where the SLC is thinly feathered at the edges but works well above a few millimetres deep. You really want to use a roller with a reasonable spike length too, around 20mm or more, you don't want the SLC totally saturating the spikes and swamping the whole roller.
http://www.tradetiler.com/catalogsearch/result/?q=spiked+roller
Me too!.....through a gap in the floor.....into the ceiling void, out of the downlighters and onto the tiled kitchen floor....and tidied up before the customer got home...phew!!!
i use a pin-leveler quite a lot from Refina and have done for a long time , but i use it on modified screeds and not SLC pour's , do anyone of you know where to get them buckets on wheels that have a tipping mechanism so you can wheel them about and pour from them ,someone posted a great picture a while back ,and i never got to the bottom of it them ???. thanks if you do know .....
There you go Dave
Ceramic Tiling Tools, Raimondi Tools UK & Ireland
trimline have one at the moment Dave its taking up a lot of space in their trade counter i sure you could get it for a cheeky offer
Like a few tilers said self leveller not what it says ,ok to do a diy yourself on a small area ,as big areas ,you can make it worse than when you started ,as weve all seen ,
[automerge]1606837220[/automerge]
My mat uses his tiling trowel,the cerated edge to pull it about and to take theair out ofit works well
Hi , I seem to be doing something wrong when I self level floors, they never are flat after I have used self leveller ? I recently self levelled over a chip board floor that had old adhesive stuck too it then over boarded with cement board and still had too build the tiles up with adhesive to make the floor flat? I used the correct slc and mixed it to the manufacturers instructions. Would a spiked roller help with the slc process? :smilewinkgrin:
Little tip don't try doing it in one go apply a thin coat use two even three let it cure fully between coats, you may need to apply a primer between coats depending on the product used and especially over ufh rushing your prep effects the project finish.
2020Tiling,
Wayne Brown,
2020Tiling,
Wayne Brown,
