monty 63 dry cutting trav - sigma who
cam_low
After hearing the sigma dry cuts trav with ease I thought I would give it a go on a H&F trav floor I had to do...
RESULT
Three scores and a snap.
sigma who (awaiting ambush from the sigma posse)
I was cutting travertine (450x450)last sunday on a rubi ts60 left a bit of a rough edge though.
RESULT
I have cut a few bits of trav on a 3bm and it was Ok. not the best cut of course as you should always use an electric machine but it cut. I have found that the trav with loads of filler will always shatter.
The quality of the travertine will obviously get better or poorer results. As for using a dry cutter then fine if it works then do it.
Sigma, can you tell me my nearest stockist please so I can go and have a play on a 900 cutter cheers
I seem to remember Tile Depot being a stockist, Sigma UK will need to confirm but Enfield is your nearest I believe.
Address:
3/4 Clock Parade
London Road
Enfield
EN2 6JG
Address:
3/4 Clock Parade
London Road
Enfield
EN2 6JG
Yes Tile Depot has them. Not sure if they will have a 900 to play around with but they will have some cutters there.
cam_low,
Sigma UK,
cam_low,
Sigma UK,
