Discuss 600 x 600 Porcelain tiles on a worktop in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
K
kendo1
That would work. Quite deep when you add it all together including adhesive and tile.
You realise the amount of work involved, and it would be cheaper and less labour intensive using a worktop?
I'm still trying to put you off! :)
You need to seal the underside of the ply.
Shultzy
I think about 51mm.
"You need to seal the underside of the ply." with what and why?
"it would be cheaper and less labour intensive using a worktop" you mean the normal formica covered chipboard!
K
kendo1
Look at the recommendations of the adhesive you will be using. It should mention a primer or sealer. The ply expands and contracts with moisture, so stop the moisture getting to the underside and sides of the ply. You normally don't seal the top surface as the adhesive does not adhere as well.
nybor62
there are thousands of tilers on this forum, and i bet not 1 as a tiled work surface
simple answer its not that practical imo
Reply to 600 x 600 Porcelain tiles on a worktop in the America area at TilersForums.com
mcgtech
