Tiling onto Plywood
R
rustylt2
Have a job to do where the old kitchen wall tiles have been removed and some of the plaster has come away too. I was thinking the quickest wasy would be to screw 6mm plywood to the wall and tile onto that - nice even surface. What is the best primer to use before tiling? Tiles are just normal 100mm ceramic. Any other preperation required also?
Available at guess where.....Gaz
HardieBacker™ 1/4'' Cement Board, with EZ Grid® Technology
HardieBacker™ 1/4'' Cement Board, with EZ Grid® Technology, for floors and countertops is America´s best selling 1/4'' board. It's the solution you can trust for your wet area floors, walls, ceilings, and countertops. This no-mesh board is the lightest cement board available and cuts easily, even in tight, awkward spaces. View Features & Benefits View Warranty View FAQs View Installation Instructions
Gaz, what sizes do topps sell Hardie 6mm, I've been getting 1.50 x .900 for about £16.00 a sheet Thanks
1.2 x .8 m this was recently changed to this size for punters cars.... total coverage per sheet .96m2......£11.99 retail...£10 trade unless you know me !!...lol...Gaz
Yep..the need for speed Drew...its money..an occupation...livelyhood...................not a hobby..............Gaz
How is it any quicker than drywall addy?
You'd have to prime the back of the plasterboard with acrylic for a kick off.
no you dont hes right drew and most tilers will have tile adhesive but not dry wall adhesive
Yes you do.
The rapid set is cement based, so the board has to be sealed with acrylic to reduce any chance of a reaction between that and the gypsum, just like you need to seal the front when you tile with cement based addy.
It is also at least 3 times the price, takes longer to go off, and is harder to use than dri-wall addy is.
I honestly can't see a single benefit from using that over dri-wall.
no i dont never have never will :lol: help
Even when using a cement based adhesive to fix a large format porc' or heavy travertine?
Chances are that it'll be fine, but why risk it for a few minutes and a couple of pounds?
You should look at using Nicobond Unique when tiling onto plaster, or plasterboard. It's gypsum based, so no need to worry about any reactions.
It also sets full in 1 hour.
drywall adhesive is cement based and so is rapidset adhesive....you don't prime plaster boards to dot & dab plaster boards with drywall or rapidset......you prime the face side only to slow the setting down if tiling but it is not a necessity.....
Yes you do.
Gypsum is sandwiched, it dosn't make any contact with any adhesive.(.except for edges)...so how can it react.......no chemical mix-up...gaz
have to be quick then have used there rapid took 3 days to dry not to impressed not all adhesive manufactures recommend to prime plasterboard and also lots of little tricks you find out over the years which are not recommended but work :yes:
thanks for the elp :hurray: i will try to behave :8:
Dri-wall adhesive is gypsum based.
http://www.british-gypsum.bpb.co.uk...roc_accessories/gyproc_dri-wall_adhesive.aspx
I know all that.
But it is common practice to seal the face before using a cement based addy, it is up here at least, so why not the back too?
What about the price difference?
Around 16-20 for 20kg of rapid, or £6 for 25kg of dri-wall.
3 days, for RapidFlex to set:huh2:
I use it all the time, even on days like today when it cold and wet, it sets in an hour at most.
Unique is ready to grout in 1 hour. great stuff.
sometimes i know you get a bad batch but i am also a wholesaler of PCI so it would cost me a bit :grin:
Tiling onto Plywood
rustylt2,
grumpygrouter,
rustylt2,
grumpygrouter,
