Musivarius
I've never used any mechanical saws before, all my cutting has been with the hammer and hardie up to now. For the my Roman mosaic copies I buy pre cut marble tesserae (tiles), all with a uniform 10mm thickness but an irregular profile.
The finished mosaic looks as if all the tesserae have been hand cut instead of the modern 10mm x 10mm x 10mm cubes and they have been tumbled so no grinding down needed. It would be a whole lot better if I can cut my own, it's cheaper plus I do the quality control.
So.... I can get 98mm x 98mm x 8mm tumbled marble tiles in the colours I need. I cut them into strips varying in width 8mm - 12mm. Then cut the strips into 8mm - 12mm 'cubes'.
Each kilo of marble gets me about 350 tesserae, I need about 7,000 per square metre.
What's the best wet saw for this? I'll try to hire one first to see how I get on. It would also need to cut harder material such as Verde Guatamala.
Bit of a long post but there's only one supplier of this cut and it just occured to me to cut my own rather than getting them in from Italy.
Cheers (I've tried to post an image but I can only get this link)
ROMAN MOSAIC WORKSHOPS - Buy marble
