Discuss Uncoupling membrane in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Chris Gibbs
I've just had a scare that a tile had cracked on a 30m porcelain floor that i laid about a month ago... panic over, it was just something stuck to the surface (glue I think) anyway I then thought about it... would it be a nightmare removing a tile 600 x 600 from an uncoupling membrane (durabase) what would be the best way without lifting the membrane?
Thanks in advance.
J Sid
Rake out grout joint and hit in the middle of the tile with a hammer and work out to the edges
Dan
Admin
Staff member
Possibly need a Fein Multimaster or something similar with a rasp head on it to get the adhesive back down to the membrane.
Basically, like this video, but don't drill. Just whack it with a hammer.
Dan
Admin
Staff member
This.
Had to do one the other week, a chipped one had appeared :(
I racked out the grout,smacked it with a hammer in the middle and got it out that way .
Luckily I only put a dab in each corner and one int middle, so it was easy ;)
Just for the record. Don't do that. He's joking lol. You need 100% coverage on the tile on floors, else you will get more cracks than a Spearmint Rhinos.
H
hmtiling
When I've had to replace a tile on durabase/ditra I've done as above but gone down to the substrate and replaced the membrane too.
One Day
I try and cut through the grout line and through the ditra to the sub floor. Usually knackers a few blades in the process. Then it's a lot easier smashing and tearing it up.
widler
I leave it up to the green badge guys to give advice , I'm just here for the craic, and to make friends , as I have none :(
Reply to Uncoupling membrane in the Canada area at TilersForums.com
mcgtech
