the bathroom was given a coat of bonding then skimmed to give added strength due to tile weight.
since i bought the tiles,sealer and adhesive all from the same tile shop i'll go back and kick up a fuss and demand they stand the cost of the strip and reseal.
finally what is the best gear to use to strip and reseal
cheers all
You won't want to hear this but the gentleman who fixed travertine to this substrate was not a 'tiler'. You've got more serious issues than just the sealing problem.
1) Without knowing the size of this travetine, it's still likely that it exceeded the safe weights for plaster - 20kg per sq/m. The room should have been boarded out.
2) Even if you meet the safe weight limits - the plaster should have been allowed 4 weeks to dry, especially in this weather.
Where does this leave you? With a hazerdous situation whereby the weight of the tiles & adhesive could pull the skim from the walls resulting in an avalanche of tiles. Sounds dramatic - but that's where you may well be.
You need to address this issue with the fixer in the first instance, although I wouldn't be inclined to trust him to put it right. Legally, you do need to offer him the chance to rectify. Sorry, you may not want to hear this but these are the facts based on info provided.
Andrew
