Tiling on to old lime plaster
Hi,
I'll be moving in to my first house soon which was built in 1890 from stone. The bathroom is currently downstairs in an extension. Looking to move this upstairs in to the small bedroom.
The problem is that the internal walls are lime plaster. How do I go about tiling them?
I've read about the need for them to breathe and no products like cement to be near them.
I've heard you can tile with lime adhesive, but does a certain type of tile need to be used? The other option I see is studding these walls then using cement board on top, allowing airflow behind. Unfortunately, it's a tiny room so need to keep the space if poss.
Any help would be great, cheers
If it's the original lime plaster it's nearly 130 years old,so it may be wiser to take it back to brick & start with a blank canvass if you do go back to brick don't forget to wear a respirator mask for the dust Jack & make sure there's plenty of ventilation also.
If room is tight and you aim to remove the existing lime plaster, you could render the stone walls with a 1:1 :6 cement ,lime, sand mix and tile onto this.
Jack, if its sand lime mortar and its listed you need to replace with the same, if its sand lime mortar and its not listed, jnock off board and tile
Jack Fairbrother,
Tile Fix Direct,
Jack Fairbrother,
Tile Fix Direct,
