Small waste trap/cover
CJ
Have a job coming up which used to be a utility area. This area has 2 waste/drains. One from the kitchen waste and the other from the bathroom sink/bath.
The customer wants them tiled over, but obviously needs the access. Tiled the recessed manhole covers before, but never seen small drain covers??
Other than knocking something up myself, I cannot remember even seeing small covers myself??
Any ideas?
No pics unfortunately, the floor has been screeded, (sort of, ;()
No backer boards going down.
Could poss use a wet room cover :thumbsup:
As as this room is going to be used as an office, of sorts, I was wondering about drain smells wafting in when a sermon is being sorted. (Trainee rev, apparently)
Cheers all. :thumbsup:
Sadly no matter how you tile the floor, you can't do anything about the waft of BS as it's being delivered
I did the same in my house I turned my utility room into an office......I just cut some thick pieces of wood to use as a bung....wedged it in leaving about half inch gap from the top.....Silicon round it to seal it and put some adesive on to before tiling over it....don't get any poo smells...However its more of a permanent fix than an accessible one..
Probably have a lynch mob after me for saying this, you could block holes, and fix tiles over offending holes with 4 blobs of Silicon, and Silicon joints instead of grout, which will help you remember where pipes are and make it simple to remove if need be
It's one of them..........tile over. They will get a blocked drain.
Make a removable section.........it'll never need access.
That's why I suggested finding out what else is connected to that run. It's possible that nothing else is connected in which case you can block it off at the man hole access point with a rubber bung.
Both of these drains go to the main man hole access point.
Drain 1 is form kitchen......sink & dishwasher
drain 2 is from bathroom....sink/bath, but also has a gutter downpipe in it. That is being boxed in/insulated to hide rain water noise......hence she doesn't want to be constantly busting for a pee. 🙂
These 2 drains are less than 5' from the man hole, which SHOULD be ok to tile over........but Sod's law??
CJ,
CJ,
CJ,
CJ,
