Discuss How to stop this cutting problem in the Canada Tile Advice area at TilersForums.com.
443
Cheshire
I'm cutting 10mm thick porcelain and have cut three tiles this morning (600mm) and all three have chipped.
How can I stop this happening?
Wishiwasatoptiler
1,108
Northeast
I had similar the other day with my sigma, 600x300 porcelain, put it down to not applying even pressure across the whole score as it occurred only near the edge and that seem to fix it, maybe one of the other lads with more sigma experience and help us both.
F
Flintstone
Common problem which I’ve never managed to find a reason to. But as above, if the cut is big enough, snap it over your leg or put it on a flat surface with a nail or alike under the score line at one end, only a bit and push down on the tile
Andy Allen
1,318
Gloucester
Had this a few times from what I have found out is it's due to the tiles being over fired which makes them brittle, another batch of the same tile may cut perfect with no issues...
Reply to How to stop this cutting problem in the Canada Tile Advice area at TilersForums.com
