Discuss How to stop this cutting problem in the Canada Tile Advice area at TilersForums.com.
As Antonio says, break 10-20mm from the tile edge.
Also helps (with "sensitive" tiles) if you nudge the tile away a few mm up from the measure bar before breaking.
And make sure there are no bits of rubbish under the tile, clogging up the spring beds in that area.
I also find that on longer tiles, a little backward score - say 50mm, before scoring forwards can help a clean break.
I back score every tile
443
Cheshire
Well as is common, as soon as I had posted the question I found the answer!
It seems on the last couple of jobs using smaller tiles I have begun to start crunching the tiles from the far side of my cutter instead of at the measure side, when I realised what i'd been doing and started doing it PROPERLY, I had no further troubles. (silly b*gger)
Thanks for the responses ;)
ps what do you mean by back score @impish?, make a deeper score?
Reply to How to stop this cutting problem in the Canada Tile Advice area at TilersForums.com
