Lakey
- Reaction score
- 24
Hey guys
Was wondering if anyone could give me some advice re a floor tiling job I have coming up?
The area is approx. 20-25m2 and will be using 600x300 porcelains.
The floor is 2/3rds 20mm floorboards and 1/3 concrete as it is a kitchen and dining room that has had a dividing wall taken down to make one large room.
The timber floor area is between 5-10mm lower than the concrete floor and is generally quite uneven as is the concrete.
So do I Hardie the timber area then SLC the entire room or......?
Will I need an antifracture membrane at all?
Will I need a transition joint between the 2 substrates and as the tiles will be laid in a brick bond can the join be a silicone join following the laying pattern?
Many thanks
Many thanks
