Hi,
I'm in a process of prepping before retiling my bathroom. I've stripped the old tiles with adhesive down to some old plaster (I think it is an old sand and cement coat). I've also installed the STS tile backing boards on the other wall where the new bath with a shower will go. See the photos attached.
Can anyone tell me whether I should be tanking the boarded/plastered corner area above the bath?
Will some special adhesive be needed or the standard wall and floor tile adhesive will do like the one below?
Finally, if the tanking is needed, do I need to prime after tanking and if so what type of primer to use there?
Thanks in advance.
https://www.NoLinksToThis/p/no-nons...a2IiApn8tf22IRTY8kgaAhH0EALw_wcB&gclsrc=aw.ds
Thanks in advance.
