Discuss Broken up asphalt floor to be tiled?? in the UK Tiling Forum area at TilersForums.com.
waggy
Hi Guys
Ive not been on for a while! But have a problem with a job a job that I have started today. The customer took the existing tiles up of the asphalt floor, and about 1 1/2 SQ M of the asphalt has come up with the tiles. The asphalt is on top of a concrete screed which is perfectly solid and dry. I was thinking of leveling over the floor in that area to get it level. But I have been worried about the floor failing because where I do the leveling will be solid, and as you know the asphalt will be hollow which will create vibration when walked on. |Can anyone help and advise, as i was thinking of decoupling membrane or fibre reinforced leveler, to go over it all.:mad2:
White Room
If some has allready come up and as you state sounding hollow..........
Take it up to save any problems later
Daz
Surely your issue is the same as blown plaster on a wall and you wouldn't tile on that would you?
Get rid of all loose areas before making good :thumbsup:, IMO.
Reply to Broken up asphalt floor to be tiled?? in the UK Tiling Forum area at TilersForums.com
