Discuss Black Quartz Floor Tiles in the UK Tiling Forum area at TilersForums.com.
Damian99
I had a builder lay these tiles for me but i grouted them with black grout.
I cleaned off the excess grout with clean water and a sponge and cleaned off the haze with a soft cloth. But some of the tiles seem to have gone very dull in certain areas, as if the haze hasn't been cleaned off correctly, even though it has. Done anyone know why this has happened and if there is anything i can do to rectify this problem.
thanks.
brian c
Did you seal them with an impregnator?these tiles normally need sealed and this could be your problem.
doug boardley
it does sound as tho' they may have absorbed the water, if this is the case, it would need to expunge before applying a sealer imo
Damian99
No they were not sealed beforehand. I have sent for some sealer(seems a bit late now) is there anything i can do to rescue the problem areas or is my wife going to give me grief for ever more?
brian c
As Doug says let them dry out and then try sealing them but imo they should have been sealed after fixing.
Damian99
ok thanks. Is there anything else i can use on them after sealing then to try and bring some of the shine/sparkle back to them.
Also what should i use to keep them clean on a regular basis.
Thanks for advice
DHTiling
You need to remove the grout from the tiles pores first before sealing....this will be why they have gone dull..
rub your hand across the tile.....dose it feel slightly coarse compared to the ones that are shiny..?..
Damian99
Not particularly, they just look as though the polished finish has come off(if you can understand what i mean) The dull areas don't really feel any different to touch.
Reply to Black Quartz Floor Tiles in the UK Tiling Forum area at TilersForums.com
  • Sticky
