Discuss Removing timber floorboards for tiling in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hello everyone ,I am a diy tiler and just joined the forum as i will be doing a lot of tiling with a new project /old house in hand .
I want to turn one of the upstairs bedrooms into a bathroom in our old cottage. There are standard pine floorboards in every room including this one at the moment.
Once turned into a bathroom the floors will be tiled .
My question is if i remove the floorboards can i replace them with 18mm plywood (so that the floor level remains close to original) and can i tile directly over them after sealing the plywood surface ?
Or is there a better way of doing this , perhaps using OSB3 etc instead of plywood ?
Hi, I would overboard the floor with a moisture resistant flooring grade chipboard (tounge and groove). Glue the joins. Then overboard with a cement based backer board (no more ply/Hardie) bedded on adhesive and screwed down. Fibreglass tape the joins for good measure,then tile. Will be absolutely solid đź‘Ť
Thank you very much for the advice , i had to google some of the stuff above but i think i have a good idea now.
A few mini questions though ;
- The chipboard (P5) seems to come in 18mm and 22mm version . Would i get away with 18mm one ?
-Also will i have to glue the chipboard on to the joists as well as screwing them down ?
Dave
No need to glue if screwed. And 22mm if possible but 18 will suffice if nogged sufficiently
Reply to Removing timber floorboards for tiling in the America area at TilersForums.com
Dawz84
