Discuss Cutting down a big tile into smaller in the Canada Tile Advice area at TilersForums.com.
cornsack
Bit of a funny one. Not something I have messed with before. In the small amount of tiling I have done, cut edges have always been hidden in corners.
Looking at doing a small repair for a client after new shower installation. Please see photos.
Customer couldn't find exact match for these old tiles but picked up a larger tile (9mm thick) that's not far off. The idea is to cut it down into the smaller strips.
I have made customer fully aware that the cut pieces will not match and the edges won't be so smooth. He is aware and happy to proceed. It's just for a room that is going to be an airbnb rental. He's also going to get some kind of shampoo bottle rack thing that will partially cover it anyway.
Question is (as an amateur) what would be the best way to get a cleaner cut -
1. Cut a big enough piece off the tile using a grinder and then cut down to shape in a small score and snap.
Or
2. Make all of the cuts using a grinder ONLY.
Also, any recommendations on a good stone/file/pad for rubbing the edges down after would be great.
Tony_C
Can you not just use a score and snap to do both cuts?
Looks like it will be a tricky area to patch in behind the tile also
You can get pads from ATS or Pro Tiler Tools but I bought these from ebay and they have done the job so far.
cornsack
Thanks for the quick response @Tony_C.
I don't have a score and snap large enough for that tile yet, only been doing smaller metro tiles etc so far and borrowed a mates for large format but he's on holiday. Been meaning to get one of my own so maybe now is the time!
Patching shouldn't be too tricky. I can dab a board to the perfect depth.
Tony_C
Use the tools you have then, use the grinder and cut one large piece and grind some false grout lines in that piece to match the neighboring tiles your patching beside
The original grout looks like it’s in need of attention too, or you could well be repairing it again, certainly sooner than your client would imagine.
cornsack
What makes you say that? Little discoloration but seems otherwise sound.
Was planning to fit the replacement tiles and grout in. Would rake out any surrounding grout but only as far as necessary.
Cut the tile down with a grinder to a size your score and snap can deal with then use your score and snap to cut tiles to size and then dress the edge with diamond hand pads
Reply to Cutting down a big tile into smaller in the Canada Tile Advice area at TilersForums.com
Teejay
