Discuss Which electric ufh system in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
H
hmtiling
Scenario, the floor needs levelling and ufh. Why would I level, insulate, carrier mat and tile as opposed to insulate ,ufh mat, level then tile?
Sell it to me guys!
Sell it to me guys!
I can't because I would do the second unless floor runs 2 " then I would level twice
There's a few factors to consider when choosing a system for me. If a floor needs some levelling and im fitting porcelain tiles I'll most likely use a mesh system and level over it.
If the floor is good and doesn't need levelling, or I want uncoupling, I'll most likely use a membrane system. Also if it's a more complicated layout.
There really is no problem tiling straight over a membrane ufh system, you fill the cavity as you go.
Wayne Brown
Check out our sponsor the wetroom store below used one of their kits this week and decent quality they do a loose wire system , mats do float in SLC stainless stapels fired into the insulation board and may mesh hold it in place obviously keep well away from the wire .kop
I don't want to upset you, Wayne, but you have fitted that mat upside down, and you have made a fundamental error by taping over the cold tail connector like that, that must be left exposed and encased in the SLC .
Wayne Brown
Perposely did it like that bud well spotted hawk eye to protect the cable bud alot been going on in there floor levels were 40mm difference one to the other not worried about to heat the room as has a big towel rail and a rad it's more to dry the floor up after showering sensors blub is exposed is on top of insulation but thanks for the comments mate . Kop
Spare Tool
Andy's right Wayne, just for future installs the worse thing you can do is tape over the join to cold tails, and also the crimped end of the wires, think its something like 90% cause of ufh failures, tape the ufh wire down and the cold tail yes but leave a gap in the tape so the joins can be fully encased in slc, or ay the very least tile adhesive..
Reply to Which electric ufh system in the Tiling on Underfloor Heating area at TilersForums.com
Dawz84
