Hole Cutter Recommendations
Lakey
Chaps
Looking to invest in a new set of hole cutters.
I previously had the Marcrist Wet drill kit which has served me well.
I'm after preferably a dry kit to include 6mm, 8mm, 32mm & 40mm as well as a hole size enlarger bit.
Anything else i'm missing?
Cheers
Previously with a cordless drill however am quite tempted by an M14 range
I've used grinder now for many years.
not that I do much 6mm but find they don't last very long using a grinder. That may just be me being impatient 😵 but would never ho back to a drill now
M14 is the way to go these days.
I get all mine direct from China. Have done for many years now.
The M14 ones I have are diatools ones from China, same as pro tilers ones I believe . I've found today that my 32mm is about done, not drilled many holes really probably 10 to 15 holes? Not sure what the life expectancy is from them
By the way- Lakey, I recommend you get yourself a decent set of Electroplated hole saws too. Always worth having. Wet cut only.
Localtiler- that doesn’t seem too bad.
I’ve tried various branded bits and they perform no better on the very hard porcelain.
Lakey,
demi34,
Lakey,
demi34,
