Discuss Hole Cutter Recommendations in the Tile Cutters area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Lakey
Chaps
Looking to invest in a new set of hole cutters.
I previously had the Marcrist Wet drill kit which has served me well.
I'm after preferably a dry kit to include 6mm, 8mm, 32mm & 40mm as well as a hole size enlarger bit.
Anything else i'm missing?
Cheers
J Sid
Previously with a cordless drill however am quite tempted by an M14 range
I've used grinder now for many years.
not that I do much 6mm but find they don't last very long using a grinder. That may just be me being impatient o_O but would never ho back to a drill now
Waluigi
M14 is the way to go these days.
I get all mine direct from China. Have done for many years now.
F
Flintstone
The M14 ones I have are diatools ones from China, same as pro tilers ones I believe . I've found today that my 32mm is about done, not drilled many holes really probably 10 to 15 holes? Not sure what the life expectancy is from them
Waluigi
By the way- Lakey, I recommend you get yourself a decent set of Electroplated hole saws too. Always worth having. Wet cut only.
Localtiler- that doesn’t seem too bad.
I’ve tried various branded bits and they perform no better on the very hard porcelain.
Reply to Hole Cutter Recommendations in the Tile Cutters area at TilersForums.com
Midland Commercial
