Multi room floor leveling
Wishiwasatoptiler
Hi All
Looking for some tips on mulitiroom leveling. As it is it looks like the kitchen has the highest point with the floor dipping into the utility and then into the hall again dips.
I'm wondering how others tackle these jobs.
The kitchen will need a liquid dpm so my usual way of drilling and plugging and screws to find levels cant be used either. Floors are sound concrete in an old farm cottage. No ufh.
Best liquid dpm and any advise on prep for layng slc on top of it?
What steps do others use to determine their levels in multiroom?
What do others use to set there levels.? I.E Screw heads etc.
Any help, advise and tips much appriciated.
Flooring suppliers offer a better range of Dpms and levellers as they’re more commonly used in that trade. It all depends what brands you have available. My first choice would be Ardex, but F Ball, Tremco, Uzin, Mapei etc all do good systems. Just make sure that you stick with one brand for all the products.
As regards to the levels, if you can’t plug and screw reference points then simply Silicon plastic packets in place through the whole floor, set off your laser datum and allow to dry. If the floors really rough a coat of Ardex NA before the DPM would be the first thing to do, then apply your DPM, once dry set your packers and then level up in however many coats are needed.
As above. I’ve used Tilemaster epoxy dpm, very solid once set. You prime plus grip it then you can level on top. What m2 are we talking ?
Thansk Lee for this. Some great info. I tend to use CTD so will check what they have. I like ardex so will see if i can source theirs. It seem a lot of folk glue ref points so will defo be going down that route. Can't believe i never thought to do that before.
Cheers
Found this one on evay. Says its new but missing the glasses.pic shows it has the target. Do they all come with remote john
They don’t, there’s a choice with or without remote, I chose without when I purchased, it’s easy enough to rotate, remote would be easier on much larger areas
Do you the glassses. Just had a google and the remotes are 70 pounds, not sure they can be an add on
From my understanding one is motorised, one is not. Check before you buy.
I have the motorised one and found it invaluable personally.
Great tools as John says.
I’ve never found the need to wear the glasses.
And you can use them at the same time as laying your slc, scan over your area as you work and it will give an accurate indication of where you are.
The best place to site them is on the highest point of your work area.
This is it in action.
One continuous line indicates perfectly level, a split line indicates a rise or fall in the substrate and it’s very accurate.
50C1300E-5661-446C-B9D0-85CEB585D432.jpeg 3C4D8DC7-0132-474F-B8FF-9216E75F7530.jpeg
Personally, I use DeWalt laser level. It has low power consumption, quite precious and has various mods of usability. Also, they advise a good warranty service. A good, solid choice.
Hello!
I have tried a various number of the lasers for measurements, and different tasks require different tools. So for the constructing measurements at the floor, the best available in my opinion are DeWalt and Topcon brands.
Here you can check some useful articles: Best Laser Levels of 2018 - Reviews of Self-Leveling Lasers for Home - http://www.toptenreviews.com/home/tools/best-laser-line-levels/, Laser Level - https://www.hilti.com/content/hilti/W1/US/en/services/power-tools/measuring-tools/laser-level.html, 5 Best Rotary Laser Levels (July 2018) – Reviews & Buying Guide - https://wisepick.org/best-rotary-laser-level/
Feel free to ask me any questions about lasers.
Cheers
Wishiwasatoptiler,
John Benton,
Wishiwasatoptiler,
John Benton,
