Discuss What is your floor leveling rates? in the Canada Tile Advice area at TilersForums.com.
Tony73
1,233
acton w3, london
Hi all,
What do you charge per sq.m ? or you do day /hour rates? Have done 130 sq.m a week ago and send invoice. Floor was only up to 6mm in high difference, but client wanted it perfect. Just want to see if I was not too cheap....
John Benton
1,138
Leeds
Same as Tony, all prep work on day rate + materials
L
LM
Floor layers get nothing near this commercially because for them it's more important to be smooth than level whereas for a tiler it's more important to be level than smooth which is harder to achieve. I charge £4 per mtr per coat or a min half days wage domesticcally, which ever is more. Considering you'll easily level 100 metres by lunch time it's a good opurtunity to make a few quid imo.
Absolutely agree Lee,
If it's a small area, by the day or part of.
Large area...... by the metre!
Has to be done, opportunities like that can increase the value of the work quite considerably.
Reply to What is your floor leveling rates? in the Canada Tile Advice area at TilersForums.com
  • Sticky
