Discuss How much of the wall should I tank in the Canada Tile Advice area at TilersForums.com.
monkjack
Hi all, I'm going to be fitting a new shower. I've read plenty of advice on kerdi vs liquid membrane etc etc, but one question I don't see being asked is how much of the wall should you do - lets say my bathroom is 3m by 3m and I'm putting in a 900mm Quadrant. How much of the two walls that touch would you waterproof - just the bit behind the shower and a "bit more" ? If so, can't the water go "around" the matting/membrane then?
monkjack
So what happens to any moisture that's caught. Does it just trickle down to the (now waterproof) floor and sit there until it evaporates?
monkjack
Now I'm confused. I was under the impression I waterproof - walls and floor - then fit tray on it, tile down to the tray.
macten
1,158
Nottingham
Moisture will just evaporate - If there's water trickling down behind your tiles then you've got problems!
Reply to How much of the wall should I tank in the Canada Tile Advice area at TilersForums.com
