Lining Up Walls And Floors
always, very, very rarely is it not possible . And have never found by doing so compromises the wall setting out, if it does then would rather see joints lined up.
as far as I am concerned, anyone who doesn't line floor and wall up should be first against the wall come the revolution. 🙂
You're very opinionated aren't you
Personally I just leave it up to my customer, I give them a few layout options and let them choose the one that best suits there eye, after all it doesn't really matter what I think it should look like. It is there job, there house, there opinion, there money.
Simples.....
exact.
me too . I always ask. and explain. what is best and what is not.
last word . it is up to the customer
now. jobs. more time talking. that work time 🙁
Ask the customer!
If architects and designers can't get it right what chance have customers. If you are a professional tiler then they are paying you to do it right and what the member from Essex is stating is the correct way - line up walls with floor joints where possible. Look at his portfolio of work and you will see quality and as a trusted advisor his opinion should be considered, and not derided by one line comments without also expressing an opinion on the issue.
Set a room up from the door.🙂
Ask the customer!
member from essex..........
We have to solve brain teaser???? ahahah
john is the numberone 😉
Ask the customer!
We have a member from essex:fearscream:impossible , theres no tradesmen in essex , they are all to busy getting spraytans and drinking prosseco in posh bistros :cocktail::cocktail:
And I've not said owt!:sunface:
No he's just right![/QUOTE
Ask the customer!
I agree! Lining up the floor with the main wall, is great, and normally no compromise, but lining the floor up with all 4 walls normally ends up with the walls having very odd cuts at each end and not looking great
Inform client at first visit as it will cost more tiles. Make nice big pieces no small cuts. They usually can return tiles and get money back these days for remaining tiles.
first choice, fit wet deck yourself, If not, you should tell that person, whoever that is, the position you want the drain to be.
if this can't be done then you have two real choices, set out with joints running though drain centre or full tile over drain, this could be moved around slightly to help with wall setting out.
as a last result the tiler could recommend mosaics on the deck and set out ignoring the deck and drain.
Julian as much as I agree with what your saying, most plumbers these days cant even get a bath to sit level, what chance have you got of them bothering their hairy scratchers about what way the drain sits...
Personally if I am decking out a wet room I am with the plumber start to finish to make sure the job is done right. double edged sword? if I am with him I am not tiling but again I know the current job is done right.... lesser of two evils?!?!?!... Most plumbers are ok, but again a lot don't care.
"it is getting tiled anyway, who will notice?" I have lost count of the amount of plumbers over the years that have said this to me. There is a lot of good plumbers out there, but again a lot of them are, rough for a better term of describing it.
A few weeks ago I went to tile a job and the shower tray was a bit unsecure in one corner, I pulled it and the lot wasn't stuck down, he had stuck it down to the chipboard floor with dry lining adhesive
Not to plastic and chipboard! It had been down a week and was set but wet through as moisture couldn't go anywhere
Last tray i helped a plumber fit recommend a week sand and cement mix the pre mixed bags work well think there 5:1 but I've known plumbers use tile adhesive also
The plumber come builder I'm working for next week is planning to stick a wetroom tray down to concrete with slc!
Referring back to the title of th thread, I'm doing a budget wet room next week, started it Friday, gonna line up the walls and floor for all the big balls on here
600x300 porc walls and floor but the tray area has anti slip 300x300, they don't be lining up
Flintstone,
Flintstone,
Flintstone,
Flintstone,
