Discuss How Square Should Tiles Be?? in the Australia area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
R
Robert19306
Me and my mate who is a building contractor have just started to tile my new house with some 560x560 polished porcelain tiles and are having a bit of trouble getting things square. I have only a little tiling experience and he has been tiling on and off for about 10 years with his father of 30 years experience sometimes they tile the houses they build and sometimes not but both men are extremely tidy and fussy. Basically our problem is the front edge of the tile measures 560.5 and the back measures 561.5 some 562, so we have tiles that are a bit off the square with a 3 mil grout space so we can have 4 corners meet perfectly but then the next set will not as there's always one corner sticking out too far. We have tried to rectify it with leaving some of the grout joints a minuscule amount larger but neither of us are quite happy with it and as its a large area kitchen/sunroom approx 80m2 it is getting a bit annoying. So far we have only dry laid the tiles in case of exactly this problem and are unsure what to do next. How square would you expect tiles to be? Ps their not paid for yet luckily.
StevieBoy
Me and my mate who is a building contractor have just started to tile my new house with some 560x560 tiles and are having a bit of trouble getting things square. I have only a little tiling experience and he has been tiling on and off for about 10 years with his father of 30 years experience sometimes they tile the houses they build and sometimes not but both men are extremely tidy and fussy. Basically our problem is the front edge of the tile measures 560.5 and the back measures 561.5 some 562, so we have tiles that are a bit off the square with a 3 mil grout space so we can have 4 corners meet perfectly but then the next set will not as there's always one corner sticking out too far. We have tried to rectify it with leaving some of the grout joints a minuscule amount larger but neither of us are quite happy with it and as its a large area kitchen/sunroom approx 80m2 it is getting a bit annoying. So far we have only dry laid the tiles in case of exactly this problem and are unsure what to do next. How square would you expect tiles to be? Ps their not paid for yet luckily.
Firstly, are they ceramic tiles?
StevieBoy
Basically one end is 1-1.5 MM. wider than the other.
Hmm, it's not uncommon and you can make a decent job with them, just don't use spacers.
Not easy, if your not entirely happy you could always try to get them changed - but the next batch may be as bad.
R
Robert19306
They came from a small local supplier. The brand is I believe halcon but says emotion ceramics on the box. The tile is Kenia marfil. Can be seen at emotionceramics.ca.
So not b and q
One way to deal with it is to use a chalk line and grid your floor out.
It's extra work but it'll overcome the problem.
Take the most common size and using chalk line grid out your floor in a chequerboard pattern of 9 tiles. Every 3 rows and columns. Allowing a 3mm joint on the top of the tile. So if they're 560, then grid a line every 1689mm in both directions.
So effectively u start on the left hand line, and finish SHORT on the next line, that's because the next line is the START of the next box. Clear as mud?
Forget spacers and just make sure all 9 tiles fit within your box.
As long as your chalk lines are correct u'll end up with an acceptable finish.
As you fill every box, stand back and adjust by eye an even joint.
Otherwise change em.
U won't able to use spacers, the floor will twist.
Reply to How Square Should Tiles Be?? in the Australia area at TilersForums.com
Apatel
