Discuss Cutting Really Hard Porcelain Tiles. in the Australia Tiling Forum area at TilersForums.com.
StevieBoy
I am currently doing a new build where the customer has bought some tiles from Porcelenasa.
They are 440mm x 660mm porcelain and are the hardest most evil tiles I have come across in 20 years of tiling.
I bought a Rubi TX-900n from Dave at Trade tiler as my TS -60 wouldn't entertain them and even it won't cut them properly. I have lubricated the scoring wheel with the oil from a rubi maintenance kit, scored the tile a few times either end more than once, and they just break where they want to.
My next step was to buy one of those montolit blades for my mini grinder, now it does cut them but chips the edges like you would not believe.
My wet bed cutter was the same, chipped the edges etc.
I've tried scoring with the rubi, then using the montolit but that didn't work, tried putting tape on and cut through that but that didn't change anything either.
The cuts at the
top I can get away with, as the chipped edge is disguised with the grout - but it's when you come to doing the L shapes around the top and bottom of the windows that I'm struggling with.
I contacted Dave at trade tiler, explained everything to him and the method I was using with the Tx900n and he reassured me I was doing everything correct.
So has anyone else come across these, and if so how did you cut them with no chipping?
Thanks.
StevieBoy
First try some cardboard under the tile, also once scored move the tile an inch or two down the cutter before breaking because if you look the solid centre bit of the bed is away from the edge ive had this problem with my 750 mate thats my 2 pence
Maybe try scoring back too and tapping along the back with pin hammer before trying to break on ur TX
Thanks chaps, will give both methods a try and report back next week.
Still not sure how I'm going to cut the L shaped ones though without chipping the edges. :mad:
R
Rizzle from the Portizzle
ok you are dealing with a high bake tile using cheap matirails total stress on the tile first you have to take out the stress the best way to do this is to core a 30 mm hole on the courner were your courner meets then scribe back to your core on the out side hole now grind out the shortest line on the inside of your scribe and then snap the long edge then grind out the remaining courner the times have been hard and a lot of tile manafators have cut cost this if the price we are now paying
Simon benn Leeds
Haven't used a Sigma Andy so I didn't like the post! Haha
However!! I am actually considering a large format one....
So watch this space! Haha ;)
Try and get your hands on a Kaufmann before you buy a sigma Marc, I tried the sigma the other day then tried the Kaufmann again, Kaufmann is incredible. But each to their own.
Cheers for that Simon, I'll certainly try and have a go of both machines first then!
I know where I can try both the sigma and Rubi.
The Kauffman maybe a different story tho!
Unless anyone in my area has one I can try? ;)
Reply to Cutting Really Hard Porcelain Tiles. in the Australia Tiling Forum area at TilersForums.com
  • Question
  • Sticky
  • Question
