Tiling on water resistant chipboard
Thanks for the link. It is the same with countless other manufacturers with their anti fracture/decoupling membranes, they are designed to do a job and allow for (the unspecified) "limited movement" in the substrate. I admit I am a bit sceptical (hence my earlier post) as they have been around in various forms for years and I have seem them not cope when presumably the movement exceeded the "limited movement".
I also note that many manufacturer's have designed tile adhesives to fix directly to the boards. The rubber crumb type for example cure to a bed under the tiles that will also allow for limited movement; but I along with earlier posters in this thread would not recommend this method (even though I have fixed many floors this way with no problem).
The key with the floor under discussion is to make sure it is firmly screw fixed down to the joists so that the floor is rigid with no discernible movement and that any joints are supported. The original poster can then choose from the methods given above as to how to prepare for retiling. If height is a major issue then the decoupling/anti-fracture membrane way will be the thinnest. Personally I would prefer to overboard with 6mm Hardie backer board (fixed to manufacturer's spec) because I perceive that this gives some increase in rigidity to the floor. I would also consider 6mm "no more ply" (fixed to manufacturer's spec) but only if the surface of the chipboard is very flat.
Must admit Steve totally agree, I do struggle with the idea that these ultra thin mats can cope.
Having attended Schluters wet room course and seen video evidence on how Ditra works I've a lot of faith in it but that's considerably thicker and I can visualise how it works, 0.85mm thick mat is somewhat harder to see, but I'm sure it works just fine.
My first choice would be hardie all day long, however the op insisted that even that was too high!
Hence the suggestion of the thinner type mats.
No more than that really.
Tiling on to chipboard would be fine if you knew that the joists were 300mm centres (which they are never, nearly always 400mm)
But the problem lies where they are tongued together they rarely if ever have dwangs here which will always cause to much deflection.
As above lift the carpet back and lay some thin timber under there with a little screed or something to smooth it out and use 6mm hardie or similar minimum.
The only time I would use Ditra if I absolutely had to would be if the floor was doing in mosaic.
If it's that green stuff, it's meant to be compressed under heat similar to ply, with polymers in it etc, so is meant to be okay.
But I thought overboarding it with ply was the way we recommended it on the forum. Just because we're all so uber.
We all know how ply reacts when subjected to prolonged wetting , say from a leaking toilet that doesn't get noticed lol lol ..etc..
The green chipboard is the moisture resistant one but it's still prone to swelling ...
At the end of the day , if anyone feels confident tiling direct and offers a guarantee , then that's that particular fixers choice and method ... We can only offer pro/cons of tiling to certain substrates..
Ivan, replacing the floor with 18mm ply will not solve the issue unless the joists are at 300mm centres (which they won't be) and you are going to dwang everywhere joins are very time consuming job.
We have been tiling on top of green or brown chipboard for years but always with another substrate on top whether that was 6/9/12mm plywood through the years cross laid for support screwed at 200mm centres or annular nailed. Now 12mm is seen as the minimum if still using ply but 6mm hardie or insulation board the minimum. Just so we are clear I haven't used 6mm ply for over 14 years lol
In short, you as the tradesman have a duty to advise the client of what is the standard when laying tiles to existing substrates regardless of their expectations.
What are you going to do at the edges of the room when you find out that a full sheet of chipboard goes under a stud wall into the adjacent room??
You will be compromising the integrity of the whole floor needlessly when you have been given countless other recommendations by qualified persons on this forum. Sorry to sound like this but the customer doesn't always know best.
I have put down plenty new chipboard floors to builders spec and you can clearly see deflection where tongued and not dwanged even when loaded with glue, this is why we always cross lay another substrate on top...not because the chipboard isn't suitable for the adhesive, hell this new rubbish will stick to metal and glass. But for structural purposes, you could lay another layer of chipboard the other way and tile directly onto it no problem.
6mm hardie....make a shape of 6mm between you index finger and thumb in front of your face and then tell yourself you are going to rip up a perfectly good floor for this height difference and so much more material and labour cost for no structural gain.
Hi Trustiling, OK I understand your very valid point of stud wall going into another room. I will go with the advice of placing ply on top of chipboard. Thankyou.
Id use HARDIE not PLY , much more stable ie it will not swell if it gets wet or when hot or cold 🙂
Marine ply will move as well.
Ps timber with move a tad even with the water in the addy when drying out
I think that is 15mm ply now (but i'm not sure!).
As I understand it if new floor 300mm c/c joists noggins so that can fit new 15mm (min) ply. If exist floor with joists up to 400mm c/c then can overlay with min 15mm ply fixed at 300mm screw spacings or an equivalent tile backer board (6mm Hardie, 10mm Wedi etc). These for fixing ceramic tiles not stone. It would be useful to everyone, I think if this is corrected if wrong!
A note on the water getting into wood and causing it to swell: even if overlayed with a water proof tile backer board a leak under the bath can still get into the wood floor base and spread under the tile backer board causing it to swell and lift, thus cauasing tiles to crack (usually) at joits in the backer board. This has happened to me and required 150 mile round trip to replace the tiles.
Hi mate,
I always use Schluter ditra matting on good chipboard floors with very little or ideally no deflection stuck down with ardex AF200 but if there is too much movement there then I would definitely go with a 6 or 9mm backer board glued, screwed & taped and if there is a bit of a step coming into the room I always use some thin layers of underlay to create a bit of a ramp if need be.
Hope that helps
Hi there
How is the backer board fixed, you mention glue, would that be gripfill, or should I be reading this as floor tiling cement ?
Cheers
Yep tile adhesive, floor cleaned and primed prior to this and spread addy with 6mm notched trowel and then screw down to secure. The screws hold the board in place, the adhesive fills any voids underneath.
PS Don't forget to make sure the screws are shorter than the combined thickness of the backerboard and chipboard, generally 20mm screws are fine
Ivan, yes it is cement based adhesive if it is Hardie backer board (and some other makes) as assumed in some of the above posts, but beware if it is "no more ply" board then use their special foaming adhesive as per their instructions.
I suggest you Google the brand of board you are being supplied with to get the data sheet for recommended fixing instrucxtions.
Sorry for joining the thread so late on. Our S2 adhesive will fix tiles onto chip-board and we can say this with confidence, what we can’t say is that your chip-board is of a suitable type to be tiled on to. It has been well documented that tiling to chip-board can cause problems such as tiles de-bonding or the chip-board expanding and contracting due to the addition of moisture from the adhesives. Most chip-boards are not good for tiling because they are very unstable and not treated against the ingress of moisture and those that are rarely have the tongue and groove treated which is a passage for moisture ingress. If moisture gets in on these edges it can cause a problem called “grinning”, which causes the boards to curl up at the edges and could potentially cause tiles to de-bond. That said there are some better quality chip-boards around that can be tiled directly too. These types of chip-boards may have a vinyl/Formica type covering which will help in keeping the moisture out. There are some manufacturers that will say their chip-boards cannot be tiled onto directly because they are unstable, and with that information it would be hard to guarantee any product onto an unstable substrate. British Standards 5385 state that all substrates for tiling onto must be dry, strong, stable and clean. If the chip-board you would like to tile is not the correct type then I would recommend over laying it with a 6mm tile backer board. These boards will create a sound and stable substrate to tile onto. Also the Anti-fracture Matting is designed to absorb lateral movement in heated floors not to absorb deflection, it may add something to the make up of the floor but if there is deflection something more substantial will be needed, and do not forget no matter how flexible your adhesive is your tiles are not.
Excellent post.
So good I thought it was worth repeating.
10/10
Just wandering about your slc (mainly levelflex) onto stable chipboard?
Only reason for asking is (a long long time ago maybe 6 years) i was instructed to use levelflex onto the metal computer flooring before tile installation around 300mq2, I went back about a year ago for some other works and couldn't even see a cracked joint!. As solid as the day it was laid.
I don't imagine it's an application you would recommend however it has worked like a treat.
By the way massive fan of your products!.
Excellent post.
10/10
Totally agree Steve!
Actually had occasion to speak with Glynn this morning,
really nice fella and of course not only is he a fixer, but also very knowledgeable as u can see!
Be kool if we're able to spend more time visiting the forum!
@p4ulo HardieFloor has been out for a couple of years now in 2400x500 sheet sizes. This year we launched a 1200x500x22mm smaller sheet size. This size is currently only available in CTD and Selco. It weights 15kg a sheet. You need to remember it is cement and not wood so it feels very solid and robust underfoot, doesn't expand and contract with exposure to moisture, and the tile bond strength is great.
Thanks guys for the vote of confidence on myself and our product. Has I said earlier it is because the chip-boards can be very unstable once moisture is introduced, that to tile them or Levelflex them would mean a possible failure. We need to ask why it was over laid with ply in the first place, and if the customer does not want a quality, long lasting tiling installation with a slight increase in the floor height then direct them to Carpetright. I will try to be on the forum more in the future.
Ivan Rubery,
Glynn,
Ivan Rubery,
Glynn,
