Size spacers on 60x40 trav
Midlandceramics
Views on size spacer on 60x40 trav 2mm or 3mm is it a personal choice or is there pros and cons to a diff size spacer !!
If your doing small joints a finer grout would be better used rather than the sandy ones....
There you go Midland. Its a personal thing is grout sizes. I'm going to bed before it all starts kicking off. There will be infractions issued within the hour🙂
I do like to see 2mm on wall and 3mm on floor unless it's all in same room and I like to try and continue the line from wall to floor where poss.so would use the same ! And 3mm does give you that bit of play if trav is slightly out !!
There is a britishstandard for tile spacing but as I'm on holiday I can't look it up right now.... I think my time would be better spent refilling my glass of vino...
- - - Updated - - -
Oops... Never copy and paste whilst drinking wine...
Midlandceramics,
beanz,
Midlandceramics,
beanz,
