Manufactured Curvature 60 x 30 cm Porcelain Tiles In Brick Pattern
Re: Manufactured Curvature 60 x 30 cm Porcelain Tiles In Brick Patter
Cut em into strips and pretend they were scored tiles?
Thats 4 hours of my life I wont get back..Thanks for that !
No it wasn't a game I can a sure you of that I was just get other tilers opinions on what as been quoted by The Tile Association when it is impossible not to have tile lipping with these floor tiles that are manufactured as someone said bowed that are all within EU / BS standards it's a bit unfair for The Tile Association to quote this when they should know it's impossible not to get tile lipping in a brick pattern with tiles that manufactured warped.
And if The Tile Association have stated this then they must know of someone who as achieved this for the tile association to state this I didn't state this they did in an email.
Paul can you do me a favour plz..
Start from the beginning and explain what has gone on and of you can plz post pics...
As for others... whats up ffs , give paul a chance to explain , instead of attacking him.??
Dave I can't seem to upload pics on here I can send you pics by email and I can also explain from the beginning.
Email them here >>>> HERE .. then i can add them to a reply here for you. 🙂
Ok Dave will do this tomorrow and explain.
Sir Ramic that's a shame you had them four hours in the first place.
Meaning ? Not my problem you cant explain yourself. I am not the only one totally confused by your posts ?
What don't you understand that we all know you can't get 60 x 30 cm porcelain floor tiles that are manufactured with curvatures in them that are all within EU tolerances fitted in a brick pattern without tile lipping but the tile association are stating.
In terms of lipping it states there should be no "appreciable differences" between levels across tiles.
In my opinion tile lipping is lipping which means it cannot be level across tiles if there is lipping in the tiles.
So why not just say that to start with ?
If a tile of this size is bent/warped and laid brickbond/halfbond then it will have some form of lippage.
I did what thread was you reading put your glasses on you might see a bit better we can all be funny:lol: as you have been we are all in the same game so lets all look after each other when there is truth being told instead of slagging each other off.
I like most other members feel a little confused. Is this an attack on TF? or TTA? we all know about the problems of large format tiles & brick-bond. I for one always explain to a potential customer the pitfalls of 600x300 brick-bond, sorry if I am missing something. I look forward to the outcome of this.:thumbsup:
Doug just stick up for myself as you would with people like that.
Paul .. have you done the tiling or had the tiling done for you .?
How wide are the joints .?
So do I explain this to the clients but when they accepted it then go back on it then ask the TTA and then the TTA confirm something that is impossible as in this case.
Paul you have lost me now sorry, we are all in the same game, but what are you saying? maybe there is another thread I have missed, this is a real friendly forum full of good people trying to give advice. Can you explain to me what you mean?
We cannot say anything till we know what has gone on , what the tile is and what grout width is and what the lippage amount is. etc.
Dave this client was adamant on having a 1mm joint in a brick pattern and was told by the tile shop salesman that the tiles were pre sealed and the manufactures boxes were completely blank boxes nothing regarding recommend tile joint, nothing regarding sealing, nothing regarding not to be laid in a brick pattern, nothing on flexible adhesive, nothing regarding the microscopic holes in tiles that can cause grout haze on the tile surface just completely blank boxes.
Paul, you're still not explaining the situation very well mate. Have you fitted these tiles and now the client is unhappy with the result? And as a result has contacted the TTA?
ok.. so 3mm min on floors but can go smaller IMO.. just depends on tile and size of floor area but BS5385 states 3mm min..
Some polished porcs do require a sealer to close the open pores from the polishing process , so as to avoid grout grab.
Putting 2 tiles face to face will determine the amount of bowing and if excessive then i refuse to lay brickbond.
Yeah so the TTA say they don't give out information to none members well they did to this client and I know he is not a member.
All of above is common knowledge to tilers paul.. This is taught when learning the trade..
The grout grab can be removed but lippage is not an easy fix... is it bad..?
Ok Dave client inspected and accepted all effects that was in them floor tiles none of these floor tiles were condemn for fitting or were they condemn in being used in any pattern and no joint was specified on the boxes these floor tiles are EU / BS standard approved for fitting in any which way.
Cut my comments short on the reply damit. Either your not very good at explaining yourself or are taking the preverbial. Just stop talking in riddles man...
You're not doing so bad on the proverbial yourself man with you're one liner riddles man.:thumbsup:
Have you got pictures of this floor?
I'm sorry. Your the one that is having trouble explaining as to what your after. I'm not having a go but i don't think anybody really knows what your after or asking????
Paul Crosby,
Dan,
Paul Crosby,
Dan,
